500 hp
Old Aug 3, 2009 | 10:38 PM
hunter's Avatar
Default 500 hp
anybody have any advice on reaching 500hp
Old Aug 3, 2009 | 10:55 PM
94 12valve's Avatar
a good set of 5x.012's not 370's, TUNE AFC, and 18* timing
Old Aug 3, 2009 | 10:58 PM
hunter's Avatar
cool,low on funds would like to have 500 by shied,so can i bump up timing and tune afc
Old Aug 3, 2009 | 11:37 PM
94cummins12v's Avatar
that or water meth will get you there
Old Aug 4, 2009 | 01:03 AM
Hammer's Avatar
I hope your head studded and have the head o-ringed to get to 500.
To run the timing needed to make that you will find that not being o-ringed and not having studs is a recipe for problems and alot of extra work.
Hp is not a cheap happening and we all call it "Cubic Money".It how much money you want to spend to get the needed cubes to make the power you want.....Andy
P.S.-Water Meth and no studs/o-rings=easily blown headgasket....
Old Aug 4, 2009 | 09:11 AM
xzaq103's Avatar
FormerVendor
Yeah ask Oklahoma 6 speed about no studs and some water/meth
Dont forgeta turbo to get into the 5s
Old Aug 4, 2009 | 11:17 AM
hunter's Avatar
thats my problemi dont have money to get the head studed,talked to my mechanic today he said i could advance timing to 18* but he said it would be cuttin it close,said its a lot added cylender pressure.
Old Aug 4, 2009 | 11:28 AM
Hammer's Avatar
18 degrees timing=head-gasket issue
At 16.5 degree you are pushing the envelope of safe.
No Money to the job correctly=Don't waste your time
All you will end up with is bigger problems and alot more incurred cost than you would have had you taken the time to do it correctly the first time.
My advice is stay happy with the 477 until you can do what you need to prevent bigger issues.However,I know its not my truck and you will do what you want anyway.
Old Aug 4, 2009 | 11:34 AM
hunter's Avatar
no buddy your rite do it rite the first time,proably take the ac compressor off and run it with out the intake and fuel plate just to see what kind of numbers i make
Old Aug 4, 2009 | 11:35 AM
Uncle Bubba's Avatar
If cash flow is an issue then 500hp is not the right goal in life. The more hp the more the upkeep on these trucks costs. All that extra hp wears parts out quick and it is a never ending turn around on new parts after that.
