Loud Whistling Noise
Old May 31, 2009 | 12:47 PM
Turbohunter's Avatar
Default Loud Whistling Noise
Dont know if anyone will know this one, but on my 01 Dodge Ram 2500 5.9 Diesel Automatic I seem to have a noise that I cant find where it is coming from. It does it all the time. Coming from the left side of the truck. Its a loud whistle, does not sound like any metal grinding though. I dont know if it is a pulley. The sound only happens when I hit the gas and stay on it. I can really hear it loud when driving next to a concrete barrier. Is it possible for the lift pump to squeal loud like that? anyone ever come across this?
Old May 31, 2009 | 06:04 PM
scottsjeeprolet's Avatar
Go RAVENS!!!!!!!!!
Sounds like a boost leak to me. Check the lower boot at the inter cooler on the drivers side.
They tend to rub through.
Old May 31, 2009 | 06:05 PM
coyropin's Avatar
boost leak X2
Old May 31, 2009 | 06:12 PM
94cummins12v's Avatar
counld be a multiple of things. could be like stated above a boost leak or it also coold be a large vacuum leak.
Old May 31, 2009 | 06:26 PM
ok that makes sense never thought of that..... should this be sending an engine code?
Old May 31, 2009 | 06:29 PM
not necesarily if the truck is still running the way it has been then ther will be no codes but if the diagnostics sees something wrong then it will throw a code
Old May 31, 2009 | 06:30 PM
coyropin's Avatar
no not really, low power more smoke is all
Old May 31, 2009 | 06:32 PM
actually yeah it is smoking more. How hard will it be to find the leak in the intercooler
Old May 31, 2009 | 06:34 PM
well i do know the 24v will let you know when there is low boost. with the vacuum leak you will usually notice the climate controls and stuff with vacuum will start to go haywire first. i dont know if the 24v is the same as the 12v but in our trucks the hyrdo booster for the breaks are vacuum assisted and the 4x4 hubs are vacuum operated as well as the climate controle
if there is a greater amount of smoke i would shoot torads the boost leak issue then i know on here there is a thing you can build to test your boots but forgot were it is located. do you have a boost guage on your truck
Last edited by 94cummins12v; May 31, 2009 at 06:34 PM. Reason: Automerged Doublepost
Old May 31, 2009 | 06:36 PM
yea i dont seem to be lacking boost at all. my climate controls are working fine i am lower then normal with the AC but that prolly needs a recharge. let me run out and check the hose and i wil post right back thanks for all the help
