charging issue
Old May 15, 2009 | 11:27 PM
94cummins12v's Avatar
Default charging issue
ok guys this issue has me flustered. the volt guage is at the first dash and was originally past the 14 mark a couple weeks ago. i tested tghe alternetor running with a volt meter and it was at 12.3 no matter what RPM. i made a jumper wire from the aleternator to the pos post and nothin. is this a shot alternator?
Old May 16, 2009 | 12:03 AM
stkdram55's Avatar
sounds like it, if its only charging 12 volts then yeah somethin with the alternator bad...
Old May 16, 2009 | 12:11 AM
Time for a new one. Should be charging at 14 volts or so.
Old May 16, 2009 | 12:40 AM
wt_offroad's Avatar
With the truck off, check battery voltage, then start up and check battery voltage with loads on, lights, wipers, blower, if the batt voltage is less than previous or less than 13.8 then you have a bad alternator,
Old May 16, 2009 | 09:33 PM
case closed. i bit the bullet on a new alternator and its at 14
Dec 10, 2019 10:10 AM
norcal6.5
Dec 7, 2014 07:04 PM
Oct 23, 2014 08:10 AM
hemiheath
Oct 15, 2014 11:49 AM
Oct 8, 2014 08:10 AM
