Truck Running Way To Hot
Old Apr 8, 2009 | 07:41 PM
94cummins12v's Avatar
Default Truck Running Way To Hot
ok i got the dodge running again but she is running hot, the thermostat dont pop till the last mark on the guage which i dont like. then i only drops a hair below 190 which i dont like either. i noticed it isnt blowing hot air threw the heater eather. i raplaced the radiator cap and all i have now is hot air. should i replace the thermostat as well?
Old Apr 8, 2009 | 08:19 PM
Whit's Avatar
Site Mascot
do a total flush .....you will be suprised what the glycol looks like, yes then do a new thermostate too
Old Apr 9, 2009 | 07:36 PM
flush it its full concentrate i just added after rebuild, there is only 85 miles on that engine with all new fluids
i also noticed a bubbling in my overflow bottle when i shut the truck off and open the hood
Last edited by 94cummins12v; Apr 9, 2009 at 07:36 PM. Reason: Automerged Doublepost
Old Apr 9, 2009 | 07:40 PM
7.3 Cowboy's Avatar
Are you runnin a 50/50 water/anitfreeze mix or straight anitfreeze?
bobcat67's Avatar
mine runs at just under 200 usually, but it's a CR maybe they run hotter
Old Apr 9, 2009 | 07:41 PM
well its like 3 gallons of atifreeze with 1 gallon of water
Old Apr 9, 2009 | 07:52 PM
7.3 Cowboy's Avatar
Maybe try less anitfreeze and more water? ?
Old Apr 9, 2009 | 07:59 PM
you would think the more anifreeze the cooler it would run because it is more coolant
Old Apr 9, 2009 | 08:03 PM
7.3 Cowboy's Avatar
Yeah
Old Apr 9, 2009 | 08:11 PM
bobcat67's Avatar
not true, water is a better coolant alone generally, correct me if i'm wrong but in order to use the antifreeze as a coolant you need water as a catalyst to make the antifreeze do its job
