'00 Cummins CKP Issue
Old Feb 15, 2009 | 04:33 PM
ndfoxen's Avatar
Default '00 Cummins CKP Issue
Howdy all... Weird one here, but maybe someone's seen it before. My brother has a 2000 Ram 3500 that I just installed a used engine (due to the cracked "53" block). Swap went fine, but the replacement engine had a plastic plug where the crank sensor should be. Removed plug, installed CKP sensor, and installed original engine harness. Now, we have a CKP sensor code (P0336), and the engine has very little power. From what I can tell by sticking my finger in the CKP hole, there is no tone wheel. Tried pulling signal from the cam sensor, but the CMP reads #1 TDC, and the CKP reads 60 deg. before TDC. So... am I screwed, or is there a fix other than installing another engine with a tone wheel? Thanks for any advise...
Old Feb 15, 2009 | 04:38 PM
stkdram55's Avatar
that seems like the only thing you could do,
Old Feb 15, 2009 | 04:45 PM
Red_Rattler's Avatar
High Tech Redneck
First of all whats the used motor out of?
Old Feb 17, 2009 | 10:24 PM
ndfoxen's Avatar
The used engine is out of a 2001 Ram3500, but it must be the later style that used the cam sensor to set timing. I've found that I can buy the tone wheel separately, but would the later crank accept the tone wheel, and if so, does it involve a complete teardown (crank removal) to install?
Old Feb 17, 2009 | 11:30 PM
1Tondiesel's Avatar
I would say yes, it would involve a complete teardown. I had the same issue with an engine swap in an Isuzu Rodeo. Installed the complete engine and found no tone ring. Mine wouldn't even start. I wound up having to pull the engine and put a different one in.
Don't know if it's the same for yours, but the crank on the one I did was machined for the tone wheel to fit whereas the other crank/engine wasn't. I would think it would be easier to swap it back out then teardown and install a tone ring. just my .02
Old Feb 24, 2009 | 10:00 PM
wildbill's Avatar
Any updates??
Old Feb 27, 2009 | 12:00 PM
wildbill's Avatar
Closing due to lack of response.
JoeyMiR
9
Feb 3, 2018 10:05 PM
trab123
Feb 9, 2015 09:44 AM
Nov 4, 2014 08:10 AM
Oct 28, 2014 08:10 AM
jmed795
Oct 1, 2014 09:09 PM
