Allison automatic trans for Cummins
Old Jan 30, 2009 | 11:55 AM
m1a1abram's Avatar
Default Allison automatic trans for Cummins
Have been gathering parts for a 12v 94-98 Cummins swap into a 1986 Chevy Blazer.D60 front, 14 bolt FF rear. Will be a DD, light towing, and snow plowing. Would like to know what Allison auto would be the best for swap, non electronic. I was told a Allison from a school bus would work? Any and all info will be areat help
Old Jan 31, 2009 | 12:07 PM
FHT105's Avatar
Allison 545 is 4sp without od, i have seen several of these used in older conversions, it does not require an electronic controller, hope that helps..
Old Jan 31, 2009 | 12:30 PM
MotorOilMcCall's Avatar
^^^ What he said, but its gonna suck not having OD, especially if you have 4.10's or higher in the diff's.
A 1000 or 2000 would be your best fit, however you'd need a stand alone controller to run either of them.
Honestly, you're much better off with a built 47RE/RH, because it'll fit what you have already. You won't be dropping $1K on an adapter setup.
Old Jan 31, 2009 | 02:02 PM
redneckbuckeye's Avatar
That is the route I would go as well.
Old Jan 31, 2009 | 06:41 PM
SPEAKSUP's Avatar
You should go with a built 47 I mean even Duramax guys like Buck and a couple other racers run them cause they break even whn built.
Old Jan 31, 2009 | 07:36 PM
What? I can't even understand that...
Maybe you shouldn't speakup, you should speakclearly.
Old Feb 6, 2009 | 03:13 PM
1Tondiesel's Avatar
I know some of the freightliner step van trucks like UPS uses have allisons bolted to the 5.9, not sure what the specs are on those though. I believe they are the 1000.
Old Feb 23, 2009 | 01:31 PM
m1a1abram's Avatar
Thank you for all the information Project is being put on hold due to the economy, I am still layed off
Jake9473
Jul 22, 2018 08:19 AM
dc2188
Sep 5, 2015 10:41 AM
PA 24valve
Aug 31, 2015 07:39 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
Pyrohigh
Oct 11, 2014 07:59 AM
