1999 7.3 Won't Start
Old Jan 20, 2009 | 01:42 PM
cummins24's Avatar
Default 1999 7.3 Won't Start
My dad went out to start his truck this morning and got nothing. He charged the batteries and they both read 12.5 volts. Turned the key on, went to crank it and got a couple of little ticking sounds like it does when the batteries are low or dead. He rechecked the voltage and they were still saying 12.5v. Is there anyway to test the starter? I'm stumped.
Old Jan 20, 2009 | 05:51 PM
jason's Avatar
What is the voltage when he is cranking? You could test the starter but would need an clip around amp probe.
I would guess loose cables at the batteries.
Old Jan 22, 2009 | 09:33 PM
cummins24's Avatar
voltage never changed when cranking. It ended up being a worn out starter.
Old Jan 22, 2009 | 11:36 PM
wildbill's Avatar
So the truck is mobile again then??
Old Jan 24, 2009 | 01:18 PM
wildbill's Avatar
assume the problem is fixed.
Dcbb93
Nov 30, 2015 10:18 AM
Domrig13
Dec 12, 2014 01:24 PM
custom7.3
Nov 23, 2014 10:44 PM
SHIFTNGEARS
Oct 30, 2014 05:40 PM
Altonlee
Oct 20, 2014 01:56 PM
