7.3 l loud popping noise
Old Jan 17, 2009 | 04:11 PM
mobile metalworks's Avatar
Default 7.3 l loud popping noise
Hi has anyone ever had a very loud popping noise that increases with rpm and sounds like it is coming from air box?The truck starts fine but does run a little rough,it revs up fine and doesnt seem to be a noticable loss of power.Any help would be appreciated.Thanks
I should also add that it was -30 and the truck wasnt plugged in for 9 hours.When i turned it off it was running perfect and when i started it there was a very loud popping that got a little quieter as the truck warmed up but hasnt changed since then.
Old Jan 17, 2009 | 05:23 PM
wildbill's Avatar
Leaking valve seat or popped head gasket.
Old Jan 21, 2009 | 10:42 PM
wildbill's Avatar
What's the good word!!
Old Jan 24, 2009 | 11:37 AM
It was actually 2 bent pushrods on # 2 and 4 cylinder that was caused by backpressure from a frozen catylic converter(so the mechanic says).Has anyone else ever heard of this?
Old Jan 24, 2009 | 01:06 PM
wildbill's Avatar
Frozen?? I heard of em plugging up, but nothing like that.
Old Jan 24, 2009 | 06:35 PM
mech2161's Avatar
Bent push rods... ok. Frozen cat... new to me. Even if it was I don't see it causing the bent push rods.
Old Jan 31, 2009 | 05:53 AM
wildbill's Avatar
Any luck yet??
Old Jan 31, 2009 | 08:16 AM
CumminsTurbo22's Avatar
i think on the grill they circled the problem. not that hard to fix....
Browe347
Dec 11, 2016 02:59 PM
Boatman
Mar 20, 2015 10:00 AM
Ltracer250
6.7 Liter Dodge Cummins 2013+
Feb 27, 2015 10:57 PM
Dak_summers
Jan 22, 2015 08:45 PM
2FordStrokers
Jan 11, 2015 09:40 PM
