EGT Problem on Duramax
Old Dec 27, 2008 | 04:24 PM
creg42's Avatar
Default EGT Problem on Duramax
Hello all
hope you can help I just put on an edge juice with attituted on my stock 02 duramax and with in 30 seconds the EGT went to 2200 and stayed there. I have tried it in all settings and even in stock and there is no change.
Hope someone can help
thanks chris
Old Dec 27, 2008 | 04:59 PM
wildbill's Avatar
My guess would be a faulty module. Does it still seem to run ok?? Engine doesn't miss, no white smoke??
Old Dec 27, 2008 | 09:20 PM
Sea97Stroker's Avatar
Could be a bad egt probe..I would call edge, they have pretty decent customer service.
Old Dec 27, 2008 | 11:24 PM
Johnny Cetane's Avatar
That sounds extremely high. My PPE on L3 barely saw over 1350*. If you didn't cut the wires on your probe and resplice them then I'd say you have a bad probe.
Old Dec 28, 2008 | 01:45 AM
Oilfield_Mafia's Avatar
Check the little bolt together connections where the EGT Probe meets bolts to the wires.. make sure its not grounding out against anything metal. There should be shrink tubing over the connections. If your truck engine temps are good, and the truck is running good. Im with everyone else here, and I think there is an issue with the probe or wiring.
Oh and Welcome to DieselBombers!
Old Feb 11, 2009 | 12:55 AM
2500HeavyDuty's Avatar
Originally Posted by creg42
Hello all
thanks chris
any updates on this?
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
dc2188
Sep 5, 2015 10:41 AM
Brappp306
Mar 29, 2015 08:54 PM
duramaxtuner
Dec 10, 2014 01:24 PM
