4X4 problems.
Old Dec 16, 2008 | 09:04 PM
phil's Avatar
Default 4X4 problems.
Hay there. i posted a a thread a while back about 4x4 not working, i figured out why. The shaft that slides the fork back and forth in the actuator was bent. any body know why or how this would happen.
Old Dec 16, 2008 | 09:19 PM
sstockton's Avatar
Thats pretty impressive. Its a 241DLD right? All I can think of would be the shift fork binding on something, and trying to force it in, or a bearing being shot and allowing the main shaft to move and bend that shift rail. Still, that seems pretty hard to do, those shafts seem pretty stout. If you still have it apart, I would recommend, replacing the retainer rings while you are in there. I had mine snap on my mainshaft for the hi/low fork, and luckily it just wouldn't come out of low. But I've seen them get caught between the chain drive and the gears and cause the case to crack and or shatter the housing.
Sean
Old Dec 16, 2008 | 09:35 PM
phil's Avatar
just to make sure its the actuator on the front axel.
Old Dec 16, 2008 | 11:30 PM
sstockton's Avatar
My bad. I thought you were talking about the shift fork in the tcase, not on the CAD. So you wouldn't have the Tcase apart then. I haven't had to tear my CAD apart, so I don't know how stout those actuators are on the front axle.
Sean
Old Dec 18, 2008 | 06:21 PM
ykdave's Avatar
i bent mine, smacked the vac actuator off of a rock and it ended up bending the shaft!
jimmer4dat
Sep 10, 2015 01:07 AM
Wyattbyrd
5.9L CR Performance
May 28, 2015 10:32 AM
cummins1998.5
Jan 24, 2015 03:06 PM
mabr0503
Nov 27, 2014 01:36 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
