6.2 diesel flywheel
Old Nov 23, 2008 | 07:18 AM
LOGANSTANFORTH's Avatar
Default 6.2 diesel flywheel
i cant remember.....will a small block flywheel bolt up to a 6.2......dad just picked up a 1986 4 speed manual K5 blazer for 100 bucks and him and my brother got to pull the engine and they are going to set the 6.2 out of my suburban into it......the suburban is an automatic.....the blazer is 4 speed......will the small block flywheel bolt onto the 6.2.......i worry about it being internally or externally balanced.......i might just buy a new clutch anyways.......this is going to be my new wheeler.....
Old Nov 28, 2008 | 02:35 AM
DB Admin's Avatar
Banned
I doubt it
Old Nov 29, 2008 | 10:11 PM
dont matter now......its getting a 350.......6.2 is staying in the suburban......
Old Dec 15, 2008 | 02:28 PM
puddlestomper's Avatar
Just for your info, it will bolt up, but a regular 350 flywheel isn't balanced like a 6.2 is. I didn't notice a difference when I changed mine out about 15 years ago though. DISCLAIMER:: When I worked in a transmission shop, I found both balanced and non-balanced flywheels on 6.5 and 6.2's. Supposedly, none of them had been touched since new.
Old Feb 4, 2009 | 10:07 PM
jackass_4x4's Avatar
The small block flywheel will bolt up but the only one you want is from a 400 they are balanced the same as the 6.2 the only thing is you have to change the ring gear!
Old Feb 5, 2009 | 07:04 AM
i dropped a 350 out of a 79 3/4 ton truck in it......
Jackthesmallengineguy
Nov 12, 2017 01:25 PM
NSmachine44
Aug 16, 2015 09:25 PM
Chris Thompson
For Sale
Jan 7, 2015 07:02 PM
joealto91
Dec 8, 2014 06:54 PM
wolfnexus
Nov 4, 2014 10:04 PM
