01 transmission trouble
Old Nov 8, 2008 | 09:03 AM
dhardy1357's Avatar
Default 01 transmission trouble
whenever i get on the pedal to pass someone, i get up to about 80 mph and then my truck like goes into neutral until i get back to 45. the first time it happened, it threw a P0700 and P0735. the second time, no trouble codes. i know its not my top speed limiter because i have reprogrammed it for a much higher speed and i have also been to 105 in it. i believe its my transmission doing something weird so if anybody knows anything i would appreciate all the help.
Old Nov 8, 2008 | 01:25 PM
2500HeavyDuty's Avatar
p0735 is 5th gear incorrect ratio.
sounds you limped the transmission. do you have a programmer on there? how high is it set to.
Old Nov 8, 2008 | 03:41 PM
dhardy1357's Avatar
yes. i have the quadzilla stealth 2 set at 135hp. ppe boost increase valve, aem brute force hd intake, and 4 turbo back exhaust
Old Dec 10, 2008 | 12:45 PM
wildbill's Avatar
You try different settings to see if the problem persists?
Old Dec 16, 2008 | 08:57 AM
wildbill's Avatar
Any updates?
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
Trevlar11
Dec 11, 2014 03:30 PM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
