98 dodge cummins code P0341 (CPS)
Old Mar 24, 2025 | 06:23 PM
Jackasserson's Avatar
Default 98 dodge cummins code P0341 (CPS)
So the truck has this PITA code. P0341 , cam sensor fault bank1. RPM guage works for about 3 seconds then drops to 0. No oil pressure, no temp sensor.
I replaced the cam sensor, no change, replaced the crank sensor, no change. It sounds perfectly fine when it runs, but it’s throwing itself in limp mode and won’t go past 25mph. I am completely stumped. I tested the plug, got 5v on the far right terminal. If anyone has any advice or has encountered a similar experience all advice is appreciated. The only thing I can think from here out is ECM , or timing cover needs pulled. It’s just the truck sounds great, no Blowby. Hard to believe something mechanically could be sabotaged and sound so good.
99ram3500
Mar 26, 2017 11:53 AM
roadglide
16
Nov 7, 2015 06:44 AM
Dodge Diesel Driver
8
Oct 28, 2012 05:42 PM
Gabriel J. Eder
Aug 4, 2009 09:10 PM
Hawg Hunter
14
Jul 24, 2007 11:04 PM
