Crank, no start except with starter fluid
Old Jul 8, 2024 | 09:29 PM
subsub's Avatar
Default Crank, no start except with starter fluid
Hi, all. Apologies if this has been covered but my thread search didn't catch it. The 6.5 in my sig has had intermittent trouble starting lately. Today I cranked it several times with no luck. In the 80's outside, good battery voltage, cranking fast enough, could hear the lift pump running while waiting to start, good flow with the fuel T valve open (both with the terminals in the relay block jumpered and with the relay installed), had been driven about 1.5 hours earlier, plenty of fuel in the tank. Right after I gave it a couple of squirts of starter fluid, it fired right up and ran just fine all the way home - no stalling, no stuttering/hesitating, normal smooth acceleration. Turned it off and then fired right up a couple of minutes later. Before I start tearing into it, any clear avenues to pursue? Many thanks in advance.
Old Jul 9, 2024 | 12:54 PM
backwoodsman's Avatar
I'm not familiar with the computerized engines, but on a mechanical engine I'd be looking at the glow plug system. But since you have a computer, the first step would be to check it for codes.
Old Jul 16, 2024 | 03:54 PM
subsub's Avatar
Thanks for the help, and sorry for the delay - I got swamped with other stuff. I should've checked for codes before I disconnected the batteries to check if they could hold a charge and pass a load test individually. I'm going after the glow plugs as soon as I have a chance.
DetroitDiesel
Nov 22, 2018 06:29 AM
klein444
Jun 20, 2015 11:48 PM
landers11889
Chevy/GMC Duramax 01-04 LB7
Feb 19, 2013 01:40 PM
palumbo1
Dec 7, 2011 10:17 AM
Bigred7.3
May 22, 2011 11:13 PM
