1999 5.9L idles fine but no power under load
Old Jun 22, 2024 | 04:08 PM
mtr65's Avatar
Default 1999 5.9L idles fine but no power under load
I have a 1999 Coachman RV with a 5.9L Cummins Diesel. It starts, idles, and revs in place no problem. But when driving it has no power most of the time. On a level surface, it might go 10 - 15 mph, it won't make it up even the slightest incline. The check engine light is on. The gas peddle can go to the floor and the engine doesn't rev. Once in a great while if I pump the gas, the engine will accelerate and the RV takes off. I changed the fuel filter and water separator. I'm hoping its just a part that I can replace myself and avoid the time and expense of having it towed to a shop.
cindy
Nov 11, 2016 06:47 PM
1Ton_Son
Jan 27, 2014 11:15 PM
Stealth99
13
May 23, 2013 09:03 PM
noizykrikit
Feb 1, 2011 05:55 PM
boomboom
8
May 7, 2010 11:40 PM
