Coolant drip
Old Dec 15, 2023 | 06:28 PM
LDOYLE's Avatar
Default Coolant drip
On my 01, 2500 , diesel ram , I have developed a coolant leak from the bracket where the lower radiator hose connects to the block and where the AC compressor bolts to the block . I have removed this bracket and found and replaced a 2 3/8 flat rubber washer which is the seal . All was good for over 400 miles , then the drip started again . I`m thinking the bolts are not torqued enough . Would any of you know what these bolts should be torqued at or where I can find what they should be torqued at ? Thanks for any help , Larry
DirtyMax427
06-07 LBZ Performance
Aug 9, 2011 08:37 AM
ssgstank
Jun 12, 2011 01:24 PM
wildbill
Feb 27, 2010 10:58 PM
HOLYSMOKES
Nov 18, 2008 09:57 PM
AndyMan
19
Aug 10, 2008 11:45 AM
