Electrical problem
Old Oct 13, 2022 | 05:46 PM
dreidmiller's Avatar
Default Electrical problem
I have recently, within the last 8 months, had bot batteries replaced, new cables and connectors and a new alternator but if I don't run my truck every other day, I can't start it up. Batteries both check out and the alternator runs between 14.2 and 14.6. Any ideas what it might be? I just pray it's not the ECM.
Also, I replaced the instrument cluster because my fuel guage malfunctioned. After installing the replacement, I held down the trip counter reset button, turned the key to the ON position and waited for all the guages to finish their twitching and to read the codes. I got A4 38 and A8 00. I understand the VIN thingy with the A8 code but do I need to have someone resolve it for me or is it good tor run as-is? I can't find A4 38 on any code lists I've found GOOGLING. Does anyone have an answer as to what they mean? Could they represent the issue I'm having with my charging system?
Thanks in advance.
EDIT TO ADD: Just found A4: "Ignition RUN/START circuit rationality check" still trying to ascertain the ramifications of this code.
Old Oct 13, 2022 | 06:25 PM
Default Found code list
I found this list GOOGLING:Instrument Cluster Diagnostic Trouble Codes
01 Airbag warning indicator output circuit shorted
02 Airbag warning indicator output circuit open
03 ABS indicator output circuit shorted
04 ABS indicator output circuit open
05 MIL indicator output circuit shorted
06 MIL indicator output circuit open
07 Wait to start indicator output circuit shorted
08 Wait to start indicator output circuit open
0B BTSI output circuit shorted or open
0C PRNDL switch input circuit shorted
0D PRNDL switch input circuit open
20 Panel dimmer input circuit shorted
21 Panel dimmer input circuit open
22 Headlamp switch input circuit shorted
23 Headlamp switch input circuit open
24 Turn hazard switch input circuit shorted
25 Turn hazard switch input circuit open
26 Panel illumination output circuit shorted or open
27 Courtesy/dome lamp output circuit shorted or open
28 Glovebox/map lamp output circuit shorted or open
29 Cargo lamp output circuit shorted or open
40 Wiper switch input circuit shorted
41 Wiper switch input circuit open
42 Wash/beam input circuit open
60 Passenger door lock switch input circuit shorted
61 Passenger door lock switch input circuit open or short to voltage
62 Passenger door lock switch input circuit stuck
63 Driver door lock switch input circuit shorted
64 Driver door lock switch input circuit open or short to voltage
65 Driver door lock switch input circuit stuck
66 All door lock output circuit shorted to ground or voltage
67 All door unlock output circuit shorted to ground or voltage
68 Driver door unlock output circuit shorted to ground or voltage
69 Passenger cylinder lock switch input circuit shorted
6B Passenger cylinder lock switch input circuit stuck
6C Driver cylinder lock switch input circuit shorted
6E Driver cylinder lock switch input circuit stuck
80 Incorrect odometer value found
81 Remote radio switch circuit high
82 Remote radio switch circuit stuck
A0 Internal module FLASH memory checksum failure
A1 Internal module bootloader failure
A3 BATTERY voltage open
A4 Ignition RUN/START circuit rationality check
A5 TCCM messages not received
A6 Ignition UNLOCK circuit rationality check
A7 VIN checksum error
A8 VIN previously stored
A9 PCI Bus internal failure
AA PCM messages not received
AB TCM messages not received
AC ABS messages not received
AD FCM messages not received
AE ACM messages not received
AF SKIM messages not received
B0 RKE fob battery low
B1 RKE module communication link
B2 Cluster mismatch
kerley
Nov 25, 2012 02:18 PM
Nutty Jeeps
Dec 10, 2011 07:06 PM
basketballtitan
Jul 16, 2010 08:05 AM
Wyatt Earp
46
May 20, 2008 07:40 PM
shilo
13
Apr 18, 2008 10:12 AM
