Need Help With Defueling - ECM?
Old Sep 19, 2022 | 08:39 AM
SteveOOO's Avatar
Default Need Help With Defueling - ECM?
Hello everyone and thank you for taking the time to review this and your 2 cents....
Here is what we got: Total upgrade and now under load (pulling 34' 5th Wheel) only half throttle (2200 -2500max) what could it be hummm got home pulled codes yup what I thought Code: P1693 & P0234 over boosting hummm got to be a issue from something else This should not be...Egt hover around 1000 -1200 loaded or not at 55mph. Edge Comp Box issue? turned it off driving down the HWY "O" Crap turn it on no power at all stated losing speed on flat ground? Then was told this could be a torque management issue with the ecm...
I hope someone seen this before or got a good Idea:
Here is what has been done in the last 3 weeks:
2002 Dodge Cummins 3500
  • New Xotic Head Studs
  • New BOSCH RV275 Injectors
  • New SPOOLOGIC Stage 2 Turbo (HX35 - 63mm Inducer and a 93mm Exducer - 40 PSI Boost) MAX Boost I get 12PSI on CTS3 and "NO LEAKS"
  • New Mishimoto ( Trans Cooler - Radiator - Intercooler)
  • New Fass 100GL fuel pump
  • New Edge Comp Box running 2X3 EGT over 1,200
  • New VP44 Injector Pump
  • New 4" Exhaust System Flo-Pro W/Muffler
  • Complete rebuilt Drive-Line
  • Rebuilt 47RE 800HP Torque Converter rest is stock
Thank You All Again
SteveOOO
scottxmorris
8
Mar 4, 2015 10:22 PM
24vklugger33
Jul 23, 2013 06:20 PM
captaincaveman
Apr 13, 2011 04:51 PM
Uncle Bubba
For Sale
Jan 3, 2011 08:21 AM
Uncle Bubba
For Sale
Jun 14, 2010 02:52 PM
