New brake caliper stuck open
Old Aug 31, 2020 | 08:06 PM
Caleb Ediger's Avatar
Default New brake caliper stuck open
Ok, so I recently bought a 99 24 valve Cummins. When we purchased it, it needed front brakes rotors and calipers. Also, the rear axle seals were leaking so we change those and the rear drum brakes and drums.
When we got all done putting the brakes on front and back, we bled the system properly. When we took it out for a test drive, the brakes were extremely spongy and I could press them almost all the way down to the floor. After doing some research, we ended up replacing the master cylinder. That did not fix the issue, so we also replaced the hydro booster.
After bleeding both the power steering and the brake system, we took it out for another test run. At first we were sure we had fixed the problem. But after a few minutes of stopping and braking, the brakes started to get extremely hot and we lost breaking abilities. We got it back on the lift, and realized that the front calipers got stuck in the open position , causing the brakes to rub. At this point, we don't know what to do.
Any and all advice would be helpful at this point! I gave as much detail as possible but might of forgot something.
Old Dec 15, 2021 | 05:36 PM
kerley's Avatar
could be the front brake hoses, if they are old they may have broken down internally.
fmx23
Jul 28, 2013 06:02 PM
6.9l dieseldriver
Sep 15, 2012 02:17 PM
gene.mneil
Apr 26, 2012 01:28 AM
tyler111991
Nov 22, 2010 06:53 PM
GRI
Aug 4, 2009 08:03 PM
