Engine brakes
Old May 19, 2019 | 05:55 AM
humpstowing's Avatar
Default Engine brakes
Can someone tell me if the 2012 6.7 has internal engine brake ie "Jake brake style"
Thanks Jonathan
Old May 20, 2019 | 07:12 AM
Surly someone knows something
Old May 20, 2019 | 08:48 AM
Bigg Redd's Avatar
Well mine didn't. I had to buy and install a PacBrake system, but mine is a Dodge cummins. My neighbor recently bought a 40ft 5th wheel travel trailer, which he pulls with his 2013 Ford dually with Auto. He indicated that his truck comes with "built in" engine braking ability, and the turbo is VGT and is capable of producing the back pressure necessary to also pull engine braking duty. Makes sense to me, but ya might wanna confirm that.
For some dumb *** reason I thought you were referring to the Ford 6.7. That's what I get for not using my glasses. Now, I believe the same applies to the 6.7 Cummins.
Old May 27, 2019 | 03:19 PM
thats ok mate ....Im going to fit a Pac engine brake not exhaust brake
I also now wondering if its worth removing the VGT and EGR exhaust manifold and replace it with the 5.9 manifold and upgrade the turbo
Old May 27, 2019 | 04:57 PM
Bigg Redd's Avatar
Im quite sure your VGT acts as an exhaust brake. Are you having issues with it prompting you to go thru all the hassles with installing a Pacbrake? Your exhaust braking is supposed to work well when used with the cruise control, and hauling heavy.
Old Jun 3, 2019 | 04:37 AM
The turbo is totally shot so its going to be replaced regardless due to a small engine fire that also trashed the loom but when I went looking for a loom they only show one ECM plug for the 2012 3500 but this one has 2 plugs on the ECM it also has 2 separate plugs going into the valve cove one towards the front and the other towards the rear about level with the end of the fuel rail so if im going to spend the money Ill put a none egr turbo and manifold on
1ton butcher
6.7L Performance
Jul 3, 2014 06:10 PM
H.R.D
Aug 19, 2012 12:26 PM
H.R.D
Sep 17, 2011 11:44 AM
johnnyb1
Sep 13, 2011 11:11 PM
rednekroper05
May 4, 2010 08:36 PM
