05' 5.9 common rail help ?!
Old Nov 9, 2018 | 06:26 PM
Uglybetty59's Avatar
Default 05' 5.9 common rail help ?!
So if any one can distinguish between rod knock, injectors out , cp3 bad or something els that would be great , a little bit of haze out of tail pipe , and no blow by but vsry loud knock
Old Nov 9, 2018 | 06:38 PM
My phone is trashed so thats why my post are subtle and usually spelt all kinds of fuxed up
Old Nov 9, 2018 | 08:40 PM
Bigg Redd's Avatar
Very likely an injector. The sound is rather identical. If you hear the knock up near the head area, then its likely an injector. If the knock is down low or louder in the oil pan. then its a rod.. Do you have oil pressure?
Old Nov 10, 2018 | 02:17 AM
The oil pressure guage stays above 40 at idle , when it usually qould drop down to about 20 at idle
Old Nov 11, 2018 | 10:20 PM
Bigg Redd's Avatar
More likely a failed injector...........
repogod
Jan 22, 2013 06:58 PM
Xcreek
May 29, 2012 01:57 PM
PhoenixFire
16
Nov 26, 2011 06:47 PM
ksmith
8
Nov 8, 2010 01:42 AM
betot56
Apr 22, 2010 09:43 AM
