Head gasket question
Old Sep 1, 2018 | 08:55 AM
Antwhite19's Avatar
Default Head gasket question
Hi I have a 94 12v just had the head plained .60 along with a valve job and new springs. My question is can I use a new factory head gasket or do I need a thicker gasket so the valves won't hit the Pistons? Thanks in advance, Anthony
Old Sep 3, 2018 | 02:00 AM
Crawler's Avatar
Did you have the valves recessed?
Check your PTV. You can get a 20 thicker HG from Cummins.
Old Sep 3, 2018 | 09:25 AM
Antwhite19's Avatar
yea they did a valve job, I need to wait till tm and ask if the head was plained 6 thousands or 60 thousands before I use a stock head gasket. But if it's 6 thousands with a valve job I'll be ok right?
Old Sep 3, 2018 | 02:26 PM
Crawler's Avatar
You need to find out if it was machined .600, .060, or .006
Theres a big difference. Cummins brand headgaskets come stock thickness, .010 thicker and .020 thicker.
Old Sep 3, 2018 | 02:31 PM
Crawler's Avatar
While I’ve seen heads machined more than .020
I believe .020 is the max spec per Cummins.
Old Sep 12, 2018 | 02:17 PM
94 12valve's Avatar
To the OP if the machine shop had to take .060 off your head to make it flat you will have other problems then head gasket thickness. If only .006 was removed I'd check valve face depth and use a factory gasket as long as the valve face depth is within spec.
Devon527
Feb 12, 2014 02:09 PM
CumminsCrazed
Dec 10, 2012 09:40 PM
coal rollin gear jammer
Dec 15, 2011 04:12 PM
CumminsKid6
Jan 20, 2011 06:24 PM
93_Fummins
5.9L 12V Performance
10
Jan 27, 2010 02:41 PM
