No 5v Power From ECM
Old Jul 17, 2018 | 02:39 PM
Seafarer24's Avatar
Default No 5v Power From ECM
Does anyone know why I would not have 5 Volt power or power to my fuel pump relays coming from my ECM? Pins 48 and 50 have a 12 volt supply and pin 49 appears to be a good ground.
This is an '02 24 valve 5.9 with the manual six speed. It has an Edge Juice Tuner. The engine was transplanted into this 80's Chevy truck several years ago by someone else who I do not have contact with. The PCM is bypassed. The truck was running fine on the 30 minute drive to pick up my trailer. I shut it off while I connected and then it would not restart. The engine will run if the lift and injection pumps are hotwired. The Cummins Bus pin 2 (+) is supplying 4.2 volts. The Cummins Bus pin 12 (-) is supplying 1.2 volts. Both busses are now supplied through the edge.
Thanks
Old Jul 20, 2018 | 01:11 AM
Seafarer24's Avatar
Does anyone know if the Cummins buses are supposed to change voltages based on some input?
Old Jul 21, 2018 | 11:00 AM
Seafarer24's Avatar
It turned out to be a fried transceiver on the circuit board in the tuner.
Old Aug 15, 2018 | 12:32 AM
Seafarer24's Avatar
Update: While the tuner was fried, that wasn't the actual problem. There was a fuse hidden up under the dash behind the gauges that popped. This fed pin 5 on the ECM. Once I gave it power again, it started right up.
LarryD
Jun 7, 2017 01:34 PM
cummins_guy
Nov 20, 2013 11:55 PM
Fyr1
Dec 19, 2012 08:51 PM
lawnmowerman1966
Dec 8, 2012 11:38 AM
ed101104
Sep 27, 2011 08:17 PM
