Lift pump pass though?
Old Mar 7, 2017 | 08:23 PM
Motohead1's Avatar
Default Lift pump pass though?
So I have 2002 in tank lift pump and was wondering what the little H connector is for that ties the return and pressure lines?
Is there a way to make this lift pump a pass through in case the electric pump fails?
Old Mar 14, 2017 | 05:01 AM
gh0stman's Avatar
To run anyother lift pump you will need a draw straw or a sump. Trying to pull through a dead or dieing pump will cause a restriction in pressure.
Old Mar 15, 2017 | 05:23 PM
Motohead1's Avatar
Do you know what that "H" connector between the feed and return is for?
Old Mar 16, 2017 | 04:28 AM
gh0stman's Avatar
I do not..
Old Mar 16, 2017 | 06:17 PM
Motohead1's Avatar
Looks like its a FPR that pops around 5-9psi.
Old Mar 17, 2017 | 04:35 AM
gh0stman's Avatar
I wouldn't run it that low. Bosch specs it for a minimum of 10 psi. Personally I wouldn't do less than 14 psi. I wouldn't run it. I'd park it till you get the fuel pressure sorted.
Old Mar 17, 2017 | 07:09 PM
Motohead1's Avatar
I am running a TDi ALH in my 2001 dakota. It has an 11mm VE pump and originally ran on a straw. I added a lift pump cause its not stock.
