Air dog install position??
Old Aug 3, 2016 | 05:39 PM
Iceman755's Avatar
Default Air dog install position??
Looking at installing my new air dog, I have an 03 short bed, where the hell do I mount it????? No where really good on the frame it seems anybody have help or pics?
Old Aug 3, 2016 | 09:23 PM
CumminsCoalRoller24/7's Avatar
Not sure the size but I just did a FASS on my 06 and tucked it drivers side front bed bolt- it's tight but fits! You can see it well looking from rear wheel well forward
Old Aug 3, 2016 | 09:47 PM
11B/11C's Avatar
i did the same bed bolt as coal roller. its behind that mud flap i mad on the right.
http://s1027.photobucket.com/user/jgoodwin1986/media/Mobile%20Uploads/20160801_200201_HDR_zpstppcaca8.jpg.html
Old Aug 3, 2016 | 10:26 PM
Jet A Fuel's Avatar
https://www.dieselbombers.com/dodge-...tank-drop.html
Old Aug 4, 2016 | 09:53 AM
You doing a sump w. It?
Old Aug 4, 2016 | 11:32 AM
Iceman755's Avatar
Will be doing the beans diesel sump. Looks like I need to notch out a tab on frame to put where I want. Going to leave my factory fuel return in too I think
Old Aug 4, 2016 | 10:12 PM
If you haven't done one before then here's my $0.02- run fuel down as far as possible - after getting pump mounted pull the drive shaft(make sure truck is chalked well)- lower tank by loosening 2 bolts on the drive shaft side of the tank- it will lower enough you do not need to disconnect fuel neck or factory lines- unplug factory sending unit connector by moving red clip to back of truck and then pushing toward drivers side-hook in AD- then just tighten bolts back up and reconnect drive shaft- factory lines can stay going to tank so if you need em later they are there and no need to wrestle getting tank back up. Ratchet wrench is a big time saver on tank bolts- also if using manifold for fuel return from AD make sure you don't cut the vent tube (don't ask how I know it's close)
Sump is easy - follow instructions- I used gray permatex RTV for torx holding rings in place and haven't had an issue
