Boost not reading right??
Old Aug 12, 2015 | 05:37 PM
Ha85ctd06's Avatar
Default Boost not reading right??
Hey guys new to the site. Have ?? About boost psi? I have a 06 ctd with a CAI and bully dog power pup. My boOst readings is coming from a edge insight monitor. It reads 23.67 at WOT. Sometimes 23.96 max. And that's it. Is this correct? I thought I should see at least 32psi. Any help please!
Old Aug 13, 2015 | 09:07 AM
dangerous1965's Avatar
Do you have a boost fooler? Get a real gauge Mechanical to read off the intake!
Old Aug 13, 2015 | 01:59 PM
Ha85ctd06's Avatar
No boost fooler. If I get a edge w/attitude do u think it would show the correct psi?
Old Aug 13, 2015 | 08:30 PM
probably not reads the same signal the other one reads! a real gauge will tell the truth! and if it is that low there's a problem with the turbo! Did you check for boost leaks? Any black smoke on hard take off?
Old Aug 13, 2015 | 11:28 PM
Ha85ctd06's Avatar
Got it! I do have heavy some out the back. I have the tuner set to extreme. I'm gunna have to get a few. Gauges here soon. I don't think I have any leaks
Old Aug 14, 2015 | 09:45 AM
Pull off the turbo air inlet hose and check the turbo. Then build a plug for the hole with a air connect use a regulator to pressurize system to 20 psi and you should hear a leak if not soap everything up look for bubbles! All parts available at Home Depot! I use an expandable plumbers plug!
Old Aug 14, 2015 | 12:40 PM
Ha85ctd06's Avatar
Thanks for the info. I'll let u know if I find anything!
Dangerous1965
Un4givn
10
Apr 27, 2015 01:58 AM
stewart.william.c
Feb 11, 2015 01:39 AM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
joejack6.0
Oct 25, 2014 05:41 PM
