Hard start
Old Jun 18, 2015 | 04:35 PM
Robby21NoGlowPlugs's Avatar
Default Hard start
Hard starting,no smoke unless I give it some throttle. Seems normal amount of smoke,but when I shut it down it's back to hard starting again.Regulator stuck,or bad injectors?
Old Jun 19, 2015 | 11:06 AM
rodbuilder's Avatar
If you're speaking of a hard start problem when it's been sitting over night or when it's cold it sounds like you might have a problem with the grid heater.
Use a continuity tester (ohm meter) and check continuity on the grid heater that's located at the base of the intake horn. Be sure to disconnect the wires on it first.
If the meter reads that it has resistance it's good. If there's no reading it's bad.
If it checks out you have a problem somewhere else in the fuel system.
Old Jun 26, 2015 | 01:23 AM
jkidd's Avatar
How many miles are on the injectors?
Old Jun 26, 2015 | 12:09 PM
Motorops's Avatar
FormerVendor
How many miles on the truck? Is there a fuel leak at all where air can be getting into the fuel system? Do you have a way of verifying Rail pressure during start up?
Old Jun 27, 2015 | 07:17 PM
Well I had injectors tested,4 we're bad. Replaced them with re,man's. My truck starts like a champ now like it should but,my mpg is down 3-4 and smokes lightly but constantly going down the road. I think maybe one of them is stuck. Tried two tanks with cleaner, no difference. Anyone have any suggestions? *note,injectors came from a certified bosh dealer.
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
trab123
Feb 9, 2015 09:44 AM
