lost lift pump now won't start
Old May 30, 2015 | 09:13 PM
bigd.t's Avatar
mad lost lift pump now won't start
installed new lift pump and changed fuel filter. bleed thru twice. cracked lines and I'm only getting a dribble. no fuel in injectors . fuel shut off solenoid is fine. could this be computer problem or pdm? can anyone give me a hint?:
Old May 30, 2015 | 10:22 PM
Jet A Fuel's Avatar
Welcome to Diesel Bombers
Are you getting fuel at the injectors?
Old May 30, 2015 | 10:26 PM
bigd.t's Avatar
no repeated cranking lines off
Old May 30, 2015 | 10:52 PM
Jet A Fuel's Avatar
It is possible that the injection pump failed from no lift pump pressure. Is the injection pump mechanical or electronic?
Old May 30, 2015 | 10:58 PM
bigd.t's Avatar
don't think so, but possible mechanical with electrical signals
Old May 31, 2015 | 04:04 AM
Jet A Fuel's Avatar
The only thing I could suggest is starting as near to the lift pump as possible and check for fuel there and work forward.
What about a relay for the lift pump is it clicking is the lift pump running?
Old Jun 1, 2015 | 01:27 AM
97cummins's Avatar
You could also hook up a pressure gauge and see if you have any fuel pressure from the fuel pump.
But it is possible that the fuel pump went out after the lift pump went out.
Old Jun 1, 2015 | 01:37 PM
bigd.t's Avatar
more like a signal is not telling it to open. just don't know from where or how to check
Old Jun 1, 2015 | 01:42 PM
bigd.t's Avatar
lift pump clicking fuel pump and shut off solenoid working injector not opening is this electrical computer code or pdm?
Old Jun 7, 2015 | 10:20 AM
Jet A Fuel's Avatar
Any Updates?
landon025
Sep 8, 2015 09:21 PM
Mac1997
Jul 13, 2015 05:08 AM
bigd.t
Jun 17, 2015 02:16 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
