Shift Problem
Old May 5, 2015 | 06:41 PM
AKDodge's Avatar
Default Shift Problem
I have a 2003, 2500, 5.9 Cummins with OEM Automatic Transmission. Problem is at about 120,000 miles transmission got to where does not want to shift from first to second unless I accelerate to 20 or so then let off the gas, then it will shift. Some cool mornings it will shift like it is supposed to but once it warms up I have to let off the gas and it shifts. If I am towing anything big, forget it...first gear until I get flat or going down a hill. Appears the first gear band(?) is out. Is this an easy fix or according to local Dodge Dealer, an over haul or replacement? Thanks for responding.
Old May 13, 2015 | 09:30 PM
cerberus60's Avatar
When was the last time the fluid was exchanged and the transdcuer\gov solenoid changed?
Old May 14, 2015 | 12:52 PM
AKDodge's Avatar
Trans. filter and oil was changed two years ago at about 108,000 miles, when this problem first started showing up. I have towed a big boat with it like this etc., but with the boat I can only go 15 mph from on dead stop up a hill. This is the first time I have heard about the transducer/gov solenoid. So it has not been changed. I thought there might be some thing like a solenoid etc. that would affect this. I had it into the local Dodge dealer, but their fix seems to always be a complete new replacement.
Worst case the bands are gone for that gear. I will check out the transducer.gov solenoid. thks.!!
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
rabidrabbit
Mar 6, 2015 03:47 AM
