700R4 behind Cummins
Old Feb 26, 2015 | 03:11 PM
Silver-raid-o's Avatar
Default 700R4 behind Cummins
Anyone ever put a 700R4 behind a Cummins because i cant figure out the kickdown cable. We got the engine in it and the trans in it useing a kit but nothing for the cable.
Old Feb 27, 2015 | 07:39 AM
Evenglass's Avatar
It does not have a kick down cable, it has a throttle valve or "TV" cable which controls shift point and firmness through line pressure. If it has been run at all without this cable properly set (too loose) you will burn up the clutches and ruin the transmission within a couple miles. The Internet is chocked full of info on this. Check out Bowtie Overdrives.
Old Feb 27, 2015 | 07:45 AM
Thanks for the info I will check into that.
Old Mar 19, 2015 | 09:51 PM
Smalldiesels's Avatar
Some at most put them behind the 4BT. Few others have used them behind a small Caterpillar (Perkins made) engine.
Old Mar 21, 2015 | 09:53 AM
Beagle's Avatar
the throttle valve geometry on the lever is pretty important too - found this from another site, maybe helpful...
http://www.hotrodders.com/gallery/data/500/700R4-2.jpg
Shun70
Sep 21, 2015 01:39 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
