Transmission help needed
Old Feb 1, 2015 | 12:33 AM
crusty's Avatar
Default Transmission help needed
I pulled my transmission and installed a altos 5 clutch pack in the front/direct drum and now it wont work right, there is no reverse and I have forward gears in reverse and neutral, the transfer case wont shift with the engine running but works fine with it off, the same with neutral the truck will roll backwards and forwards easily but with the engine running it is in gear in neutral and reverse and travels forward when you give it the gas, when I put it into drive it shifts fine and runs well with no issues, but there is no neutral or reverse, just cant get my head around this what I could of missed, the instructions were followed to the letter, any help would be greatly appreciated.
Old Feb 14, 2015 | 08:56 PM
crusty's Avatar
well I found the problem and all is well, tranny shifting good and the new set of twins are freakin awesome.
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
