codes from 7.3
Old Sep 30, 2014 | 08:29 PM
Altonlee's Avatar
Default codes from 7.3
How do you read codes from a 1995 ford f350 with 7.3?
Have one that has 260,000 miles, ran good till started having problems. Now to get it to start have to use starting fluid. Takes for ever to get oil pressure (low) up then it will start runs rough for bit then levels out and runs good.
My son bought this and I know nothing about it. Have always heard 7.3 was easy to work on. But do not know where to start, without knowing codes.
Thanks
alton
Old Oct 1, 2014 | 12:54 AM
joebob3093's Avatar
Moderator
You need to have a scan tool or take it somewhere to get the codes read.
Old Oct 1, 2014 | 03:57 PM
Altonlee's Avatar
I have the ao for my 2004 but I cannot find the plug.
Old Oct 1, 2014 | 06:30 PM
Altonlee's Avatar
opps I mean AE
Old Oct 1, 2014 | 07:46 PM
joebob3093's Avatar
Moderator
Call up AE, you might have to buy another one
Old Oct 2, 2014 | 11:37 AM
Altonlee's Avatar
finally found the plug someone hid it under dash on passenger side.
No codes. when running fuel only holds around 600 at 1100 rpm.
Don't know what else I should monitor in this.
There is very little to none on injector control pressure.
Any suggestions.
Old Oct 2, 2014 | 06:25 PM
joebob3093's Avatar
Moderator
Monitor ICP and duty cycle see what that says
Old Oct 3, 2014 | 04:04 PM
Altonlee's Avatar
icp @ idle=380.95 @1381rpm 863
duty cycle @ idle 14.84 @1381rpm 16.01
icp volts .43
what should these be running?
He said he has changed icp, and cam position sensor.
Thanks.
Old Oct 3, 2014 | 04:08 PM
joebob3093's Avatar
Moderator
Idle looks a little low at idle. When its cold unplug the ICP sensor and see what it does. But never ever use starting fluid on it
Old Oct 8, 2014 | 02:31 PM
Altonlee's Avatar
no start icp about 2300 no volts to icp
How does one check the hpop?
thanks
alton
mjles79
Jul 10, 2015 12:30 PM
D K
May 17, 2015 11:27 AM
KimberlysTruck
Mar 5, 2015 06:28 PM
SHIFTNGEARS
Oct 30, 2014 05:40 PM
Browe347
Sep 30, 2014 11:35 PM
