can I put my 7.3 idi on a 2001 body?
Old Sep 30, 2014 | 09:06 AM
Browe347's Avatar
Default can I put my 7.3 idi on a 2001 body?
I recently purchased a 2001 7.3 Ford Powerstroke that had a bad block I was wondering if I would be able to put a 92 7.3 IDI into where the 7.3 powerstroke was
Old Sep 30, 2014 | 10:27 AM
4x4manonbroke's Avatar
Go with a 12V Cumins .. they even have a swap kit for them .. a IDI would be going backwards all together ..
Old Sep 30, 2014 | 01:58 PM
Browe347's Avatar
That means I would have to shell out money that I don't have just to have a moving vehicle
Old Sep 30, 2014 | 02:01 PM
Browe347's Avatar
The 92s body and frame are shot but the motor is good and the 01s body is good but the motor is shot I was needing to know if I could combine the two and have a running vehicle
Old Sep 30, 2014 | 11:08 PM
Sycostang67's Avatar
If you have to get the vehicle smog tested you would be wasting your time. The older IDI would never live up the standards expected of the 01.
All that aside, it could be done but you would have a bunch of electric gizmos not happy with you. The PSD also has a drive by wire system you would need to replace with a regular throttle cable assembly. I'm not sure if the newer transmission would work with it. It should bolt to it, but working properly is another story.
Old Sep 30, 2014 | 11:35 PM
PITA ..... and the Cummins would pass En=mmisions with a Cat in the exhaust ..
Browe347
Dec 11, 2016 02:59 PM
Metz1234
Mar 3, 2016 10:20 PM
E350Hawaii
May 20, 2015 12:46 AM
Toms73
Mar 23, 2015 08:31 PM
honda89
Dec 27, 2014 06:19 PM
