Front end problems
Old Jul 5, 2014 | 08:46 PM
Jordan1233's Avatar
Default Front end problems
Hi there I just recently did my ball joints in my 1993 ford f250 turbo diesel, I found that after I took the wheel off the rotor would move in and out with the axle. I'm not sure what would cause this and but the other side was fine. Also what's an easy symptom to tell if your wheel bearings are worn? When ever I drive fast or slow I can hear a sort of growling noise in the front end almost like something is grinding. Thx.
Old Jul 6, 2014 | 03:45 PM
4x4manonbroke's Avatar
spindle could be loose, wheel bearing will need to be inspected to determine if there toast, if there is ANY pitting or flaking of the crome, there done...
ake sure you re-pack them real goood with a high temp disc brake grease ...
Old Jul 6, 2014 | 04:23 PM
Jordan1233's Avatar
Well I know the spindle isn't loose because I just put it on. I'm wondering if it could be a seal or somethig?
Old Jul 6, 2014 | 10:11 PM
If you can move the hub in and out on the spindle, your wheel bearings are not right ...
Old Jul 6, 2014 | 10:36 PM
Jordan1233's Avatar
Yeah I'm hoping it's just the wheel bearings. Should be an easy fix.
Old Jul 6, 2014 | 11:25 PM
Hope so .. post pics if you need any help .. manny folks here been in elbow deep befrore..
Old Jul 6, 2014 | 11:27 PM
Jordan1233's Avatar
Oh I've taken everything apart in there before I just forgot to take a look at the wheel bearing. Thanks a lot for the help. I'll let you know how she goes.
Old Jul 7, 2014 | 05:29 PM
there are two, one inner and one outter ... inspect both ...
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
2FordStrokers
Jan 11, 2015 09:40 PM
Cumminsman911
9
Nov 1, 2014 04:07 PM
