Manual shut off leaking
Old Jul 1, 2014 | 06:59 PM
1Incountryboy's Avatar
Default Manual shut off leaking
My injection pump is leaking from the manual shut off. How hard is it to replace the o-ring? Can I leave the pump on? Can I remove the screw and spring to fix or do I need to pull the top off because something will fall off inside?
I've tried using the search and get a lot of hits on the solenoid shut off, but having trouble finding the fix for my issue. Thank you for any help.
Jake
Old Jul 1, 2014 | 09:17 PM
novapat's Avatar
Jake
no you don't have to pull the top off. mark the shaft in relation with the lever. the shaft is splined. when you take the lever off watch how the spring goes. there is a thin washer and a o ring under in. that is the only seal on the manual shut off seal..
Old Jul 3, 2014 | 05:46 PM
Thank you Novapat! I have been really swamped at work with the 4th tomorrow and have not been able to get to it, however when I looked tonight it actually looks like it is coming from the bolt head just under the manual shut off. Trying to figure out what that is now. I have been looking for the rebuild seal kit but can not find the Bosch kit for sale. Not sure if I want to go with anything else, however I may not have a choice. Leaning to pull the pump off and replacing all the seals in the next couple of weeks. Sooner the better.
camp9
Mar 25, 2017 07:40 AM
B.k. Smith
10
Jan 7, 2015 02:29 PM
Dec 30, 2014 09:10 AM
Stox5225
Nov 18, 2014 01:04 PM
