1st gen 12v p pump conversion questions
Old May 19, 2014 | 01:03 AM
94chevy2500s's Avatar
Default 1st gen 12v p pump conversion questions
I'm p pumping a 1st gen engine and I'm wondering can I use 2nd gen 12v injectors in the 1st gen and will there any difference if I did that
Old May 20, 2014 | 10:28 PM
crashmarvin's Avatar
I've been considering p pumping my 93. What's the benefit of p pump over my stock ve?
Old May 27, 2014 | 08:50 AM
More reliable you can get good performance out of it as well as mpg's that's just a little of what it does
Old May 28, 2014 | 09:04 AM
Ok. I found one off a guy for $300. Needs new governor springs. Is there anything else I need besides the gear to do the conversion? I'm going to put a fass fuel system on so I won't be needing a new lift pump.
Old May 28, 2014 | 10:15 AM
You are going to need a pump gear housing from a newer 12 valve you will need injector lines i believe cause they won't thread on they are different threads you will need the bracket that holds the pump it's on the side of the block That's the major stuff
Old May 28, 2014 | 10:44 AM
Ok thanks
Old May 28, 2014 | 12:23 PM
geddy's uncle's Avatar
IIRC, and I could be wrong, the injectors' ports were different diameters and thread-pitches. 2nd-gen injectors might not go into a 1st-gen block at all. THAT BEING SAID, (and, IF it's true) you could probably still use 1st-gen injectors, but with new nozzles that duplicate the 2nd-gen spray/delivery/pop-off pressures
Torkjunky
Nov 20, 2018 08:46 PM
klaveric
Oct 20, 2015 07:17 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Tory4
For Sale
Feb 1, 2015 08:33 PM
