no boost
Old Apr 6, 2014 | 04:02 PM
Daniel Leipart's Avatar
Default no boost
ok so i bought this: Auto Meter | BDHZ5704 | 2in. BOOST; 0-35 PSI; MECH PHANTOM - Alligator Performance
and i bought a boost bolt from leroydiesel. I installed the bolt in the center rear position and ran my line to the gauge. started it up and got nothing revved the motor still nothing. took the line off both ends and shot air through it and it has no restrictions.
if i hold my finger over the opening on the boost bolt i don't feel anything either. so am i doing something wrong or is there something wrong?
i just put air to the gauge and it works....
Last edited by Daniel Leipart; Apr 6, 2014 at 04:02 PM. Reason: Automerged Doublepost
Old Apr 6, 2014 | 04:37 PM
Mayhem's Avatar
I don't believe that will work You will have to drill and tap the intake
Old Apr 6, 2014 | 05:09 PM
bah they why do they sell the damn thing...
Old Apr 6, 2014 | 05:12 PM
JJ Diesel's Avatar
install in the intake, after the turbo. Mine is in the upper intake plenum and works great.
Old Apr 6, 2014 | 05:15 PM
can you show me a pic where?
Old Apr 7, 2014 | 09:11 AM
racer55's Avatar
Boost bolt works fine and you installed it correctly.
Boost is load dependent so don't expect boost revving in the driveway-take it for a drive and do some hard acceleration and hill climbing/towing to see boost.
Also verify the wastegate is operating properly-at idle the wastegate lever should be pulled forward/up and should be hard to move with your finger.
Old Apr 7, 2014 | 04:12 PM
thank you racer I will go for a ride
ya it works properly, thank you for the info, I am sure I will be back as i start doing the upgrades.
Last edited by Daniel Leipart; Apr 7, 2014 at 04:12 PM. Reason: Automerged Doublepost
Old Apr 7, 2014 | 04:39 PM
racer55's Avatar
Good when you get the result you want.
Old Apr 7, 2014 | 05:04 PM
indeed
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
