6.5 turbo diesel dead
Old Apr 4, 2014 | 10:33 PM
reefermike's Avatar
Default 6.5 turbo diesel dead
1994 6.5 turbo diesel not starting, this truck has been a pain for a while now it was shuting down while driving so I replaced pmd the problem remained and slowy got worse now it dos't run,there is no fuel at injectors ,replaced transfer pump and injection pump,tried more than one pmd,replaced pcm as per gm book, tried different eprom, checked ground wire on back of block, the problem i have found with no solution is the signal to the pmd fades out after 2 or 3 pulses I checked it at the pcm exactly the same.
Were is the signal to the pcm supposed to come from?
Old Apr 6, 2014 | 09:58 AM
reefermike's Avatar
Sorry i posted this in the wrong section
And Hi I'm new !
Old Apr 7, 2014 | 04:41 PM
racer55's Avatar
Check the CPS and OS.
also verify the LP operation when the engine is running-OPS powers the LP at that time.
Google OPS relay mod and install-AC Delco ONLY for OPS and CPS and all electric parts for these.
Brclouse
Nov 18, 2015 08:44 AM
Dye Guardian
Aug 1, 2015 01:28 PM
MrMoose
Mar 15, 2015 06:05 PM
Snoobly
Dec 11, 2014 11:59 AM
Oct 24, 2014 04:40 AM
