Where is the temperature gauge sending unit on the 1996 K1500 6.5 diesel Suburban? H
Old Feb 15, 2014 | 02:26 PM
jrsavoie's Avatar
Default Where is the temperature gauge sending unit on the 1996 K1500 6.5 diesel Suburban? H
Where is the temperature gauge sending unit on the 1996 K1500 6.5 diesel Suburban? At the front of the block on the left hand/drivers side, near the injector.
How do you test it?
The temperature gauge quit working.
ACDELCO 2134396 Alternate/OEM Part Number(s): GM 19187357
Thanks
Old Feb 16, 2014 | 09:53 AM
racer55's Avatar
Yes that is the proper location for the gauge sending unit-frt of drivers side head.
The only test I can think of is to use an ohm meter to check resistance with a known temp eg:immerse the coolant contact portion in boiling water it should give a resistance reading close to 212F or 100C.
Or on a stone cold engine it should give a value close to the ambient temp.
resistance chart:
GM ECT and IAT temperature sensor resistance chart. - Ford Explorer Ranger Photo Gallery at Serious Explorations
Old Feb 16, 2014 | 10:27 AM
jrsavoie's Avatar
Thanks. I have a bad sending unit connection. I was able to get it hooked up good enough that it will work until it falls off. I ordered a new part on Amazon
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
JohnFromVt
Aug 3, 2015 06:15 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
tedbIII
Feb 1, 2015 11:09 PM
