7.3 idi turbo question
Old Feb 11, 2014 | 12:06 AM
Crazyredneck1980's Avatar
Default 7.3 idi turbo question
Ok I have the old style banks kit with the big intake box. My question is can i remove the whole box but leave the bottom hat thing that bolts to the intake that has the small hose on it. and just run a cold air intake off the turbo.also where could I put that round valve looking thing that's on the box.
Old Feb 11, 2014 | 11:50 PM
Dortiz's Avatar
Should be possible, cannot imagine why it couldn't, and what valve object are you talking about?
Old Feb 12, 2014 | 10:15 AM
The round thing with the hose on it that's bolted to the side of the intake box
Is it some kind of emissions thing is it even needed the hose comes off the front of the motor
Last edited by Crazyredneck1980; Feb 12, 2014 at 10:15 AM. Reason: Automerged Doublepost
Old Feb 12, 2014 | 11:38 AM
Dortiz's Avatar
I'm having a hard time picturing what you're talking about, is it the cdr valve?
Old Feb 12, 2014 | 03:49 PM
Sycostang67's Avatar
The CDR valve is a small can shaped deal, about the size of a tuna can. You can either find a way to plumb it into your intake or just remove it and run the hose from the motor to some random location under the truck and let it vent to the atmosphere.
Old Feb 12, 2014 | 08:35 PM
yes thats what its called is it just a breather for the crankcase
Old Feb 12, 2014 | 08:47 PM
Dortiz's Avatar
It keeps the engine from consuming a LOT of oil, and also helps to keep a runaway situation on ease, I would not get rid of it. You can relocate it though, a lot of people tap it directly into the oil fill hole
Old Feb 12, 2014 | 11:19 PM
I'll do it that way then. or by removing the banks box can it Go back to the stock location
Old Feb 12, 2014 | 11:22 PM
Dortiz's Avatar
Do not believe so, it should remain on the valve cover, but could be plumbed through the oil fill cap as an easy way
GarrettEvan
Jan 30, 2016 05:39 PM
Devon7.3
Sep 27, 2015 10:35 PM
g.logistics
9
Nov 22, 2014 08:54 AM
CO TOM
Oct 24, 2014 11:33 PM
CO TOM
Oct 16, 2014 09:55 AM
