99 PSD starter issues! Please help!
Old Feb 6, 2014 | 11:56 AM
Trigger99's Avatar
Default 99 PSD starter issues! Please help!
My early 99 PSD starter sticks engaged. It was about -20 to -30 this morning. I cycled my glow plugs 5 times and turned it over, I turned the key to the off position and the starter was stuck engaged. I tried tapping the starter to disengage, but it would not. So I pulled the positive cables and it stopped. I tapped the starter while the cables were pulled and it disengaged. I tried again with a small truck jumping my batteries, same thing. Just a week or few weeks ago I installed 2 new Caterpillar batteries. Does anyone have any idea what is going on?
Old May 5, 2014 | 06:04 PM
no1speshal's Avatar
I cannot say for certain but when mine did this I had to replace the starter. I do not think you can get just the solenoid for the starters but that may fix it also. If it is any consolation, aside from the cost it was a very easy replacement. Maybe only took me about an hour.
Old May 6, 2014 | 12:28 AM
FRIDAY88's Avatar
There's a company that sells a 12 valve starter conversion that all you need is the nose cone I do believe off of your power stroke starter and it makes your engine crank over twice as fast and is ideal for cold starting conditions
Old May 6, 2014 | 09:26 PM
deck60's Avatar
more info please this sounds aw-sum !!!!!!!
Old May 6, 2014 | 10:39 PM
FRIDAY88's Avatar
There was a website I don't remember what it was called but they took the 12valve starter and put it in the ford starter nose cone and the gear reduction spins the powerstroke over way faster
dwmeehan
Jan 29, 2025 12:13 PM
klein444
Jun 20, 2015 11:48 PM
james2562
Feb 5, 2015 09:05 PM
Polaris04
Dec 1, 2014 08:27 AM
nevadagramm
Oct 17, 2014 07:59 PM
