putting 1999 7.3 in my 1997
Old Jan 27, 2014 | 11:43 AM
css89's Avatar
Default putting 1999 7.3 in my 1997
Hi guys will this be a simple swap or will I have problems with injector wiring harness my 97 is the old style 2 connectors per valve cover . Of course 99 has single conector so will 99 harness plug and play into 97 harness at firewall
Other thing will 99 dash fit into 97 cab
Reason I ask about dash is if I have to change wiring harness in cab to make everything plug and play
Old Jan 27, 2014 | 01:12 PM
joebob3093's Avatar
Moderator
Just swap your gaskets, no reason why you can't. Not sure about the dash but I'm guessing no
Old Jan 27, 2014 | 03:18 PM
css89's Avatar
ya I know I can change gaskets but my old harness needs rebuilding and don't want to screw with it
Old Jan 27, 2014 | 04:08 PM
joebob3093's Avatar
Moderator
Then buy new valve cover gaskets, I dont think you can run the harness or gaskets from a 99 on a 97
Old Jan 27, 2014 | 08:36 PM
css89's Avatar
nope your right the reason body is different is 99 is a super duty that's why body and dash won't work
Old Jan 27, 2014 | 09:16 PM
joebob3093's Avatar
Moderator
yes i know they are diffrent, but just about anything can be done with enough time and money
Browe347
Dec 11, 2016 02:59 PM
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Toms73
Mar 23, 2015 08:31 PM
1997fordf350
Jan 15, 2015 06:12 PM
Browe347
Sep 30, 2014 11:35 PM
