Park Brake
Old Jan 14, 2014 | 08:14 PM
powerstrokin350's Avatar
Default Park Brake
Has anyone had to, or know of any tricks to getting the upper park brake cable attached to the pedal? My upper cable snapped and I got it all replaced and ran, but I can't get the little lead cylinder to drop into its hole. Old one came right out and now I'm having a hell of a time getting the new one to get in there. Thanks y'all.
Old Jan 14, 2014 | 10:43 PM
Dortiz's Avatar
That's the hardest part, the only way I know that isn't time consuming is to pull the pedal assembly for it out, then run the wire down from inside the cab
Old Jan 15, 2014 | 12:56 PM
Sycostang67's Avatar
You could loosen the adjusting bracket that's under the truck, its the metal bar with one cable connected to one side and two cables connected to the other side. It should be hanging along the outside edge of the frame on the driver side. That should give you a little more length to get it connected. Just make sure to tighten it back up when you are done.
Old Jan 16, 2014 | 01:35 AM
Thank y'all, I got it all ran, but I just can't get that damned metal cylinder piece in the damned hole. Got plenty of length and all the. Just gotta fu€|< with it more.
Hogridenfool
Nov 20, 2017 04:37 PM
Turbo67
Jul 25, 2015 02:26 PM
corksil
Jun 30, 2015 06:58 AM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
