Chevy/GMC Duramax 07.5 -10 LMM Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines
Wiring OEM Camera to Aftermarket HU
Old Jan 2, 2014 | 07:26 PM
Craig14122's Avatar
Default Wiring OEM Camera to Aftermarket HU
I have a Pioneer AVH-P4000DVD that i have had in my truck for a while.
Pioneer AVH-P4000DVD DVD receiver at Crutchfield.com
I want to add a back up camera so i do not have to get out of the truck 3 times to line up a trailer. So i purchased an OEM Bezel and Camera from eBay.
The issue is i am unsure on how to wire the camera up.
On the back of the Head Unit there is a single RCA input.
The OEM Camera has 6 wires.
This is what i think each wire is:
Yellow: Video +
Brown: Video -
Gray: Reverse Feed
Red: Ignition +
Black: Ground
White: Shield
I do not believe i have the stock wiring harness (i have not rummaged around to look).
And i am also under the impression that the Camera is 6v so i will need a http://www.ebay.com/itm/DC-DC-Converter-12V-Step-down-to-6V-3A-15W-Power-Supply-Automatic-Recovery-/161094129139?pt=BI_Circuit_Breakers_Transformers&hash=item2581f555f3.
I was gonna run the red to a 12v when key is on.
Gray to the reverse positive
Ground to ground
Cap the White
But lost on what to do with the Video positive and negitive.
Any help would be great.
Old Jan 3, 2014 | 05:29 PM
Craig14122's Avatar
I believe the Positive video will be the center of the RCA and the Negative will be the outer.
Anybody else know for sure?
Old Jan 5, 2014 | 12:37 PM
Craig14122's Avatar
Bump
Old Jun 17, 2014 | 10:35 PM
Tunk's Avatar
Call your local car audio guys and have them wire it for you. In a car audio shop in Washington and do tons of these.If its a 6volt camera you will have to use a micro relay to lower the voltage. If you still need a schematic message me and I can email an exact pdf
cumminspwr11
12
Oct 17, 2021 03:50 AM
carid
Diesel Bombers Sponsors
Dec 4, 2014 05:25 AM
Mike H
Nov 25, 2014 03:13 PM
12valve_soot
Nov 12, 2014 10:02 PM
carid
Audio Equipment/Electrical
Oct 7, 2014 03:36 AM
