v2203 in 88 s10
Old Dec 18, 2013 | 08:44 AM
spencxr80's Avatar
Default v2203 in 88 s10
this is my first post i joined so i could see what all you guys are doing
once i figure out how to post pictures i wil put some up of my adapter and modified flywheel and pullys
Old Dec 18, 2013 | 12:03 PM
FTE's Avatar
FTE
Welcome, looking forward to seeing your build!
Old Dec 20, 2013 | 06:49 AM
spencxr80's Avatar
Default how to post pics from the phone
i need help on how to post pictures from my phone i click on attach nothing happens i can not open it
Old Dec 22, 2013 | 10:58 PM
spencxr80's Avatar
Default Pictures
Here are some pictures of the progress I've made so far....
Attached Thumbnails v2203 in 88 s10-01.jpg   v2203 in 88 s10-02.jpg   v2203 in 88 s10-03.jpg   v2203 in 88 s10-04.jpg   v2203 in 88 s10-05.jpg
v2203 in 88 s10-06.jpg   v2203 in 88 s10-07.jpg   v2203 in 88 s10-08.jpg   v2203 in 88 s10-09.jpg   v2203 in 88 s10-10.jpg
Old Dec 23, 2013 | 12:54 AM
JesterGrin_1's Avatar
Keep up the good work.
Old Dec 23, 2013 | 11:40 AM
FTE's Avatar
FTE
Nice work! I never thought of welding the plate to the cast bell, but I didn't have that much cast thickness left for my spacing. You seem to have double the spacing I have. I like your belt setup, but the tensioner may not do too good on the torque side of the drive pulley.
Old Dec 23, 2013 | 12:41 PM
FTE you made me go back and look. But once I did FTE is correct about the tensioner on the Torque side and also I am not sure if the Water Pump pulley has enough contact with the belt for proper operation under load of the water pump.
Old Dec 23, 2013 | 02:29 PM
spencxr80's Avatar
im going to try out the water pump before i put another pully on it as far as the tensioner go's there is not alot to work with on the other side for a mounting location and from everything i can tell the bellhousing is cast steel so welding was not a problem but thanks for all of the info thats why i joined
Old Dec 23, 2013 | 06:02 PM
FTE's Avatar
FTE
The tensioner will work in that location locked in place, not spring loaded.
Old Dec 23, 2013 | 07:39 PM
spencxr80's Avatar
i had it running today and the tensioner alittle at idle but smooths out after that
