95 psd block heater?
Old Dec 11, 2013 | 07:51 PM
95_powerstroker's Avatar
Default 95 psd block heater?
My truck doesn't have a block heater in it right now and never has. I found a couple on ebay for about $75 (that's the element and the cord)! pretty damn good price compared to the dealerjip. they want 250 for theirs! anyways, my truck is very hard to start in the mornings. I live in NW Indiana and its been rather cold as of late. I don't want to damage anything in the motor doing a cold start, plus its sounds like hell once it actually cranks over...my question is: do you have to pull the motor to put in a block heater? heard from someone that the freeze plug is right next to the motor mount? also, any fuel or crankcase additive I could use to aid in easier starting? any help is much appreciated! thanks!
Old Dec 12, 2013 | 01:21 PM
94turbostroker's Avatar
The heater should be kind of on the oil filter housing. You should be able to get to it. I've had to replace the cord & that's easy running the cord too.
Old Dec 12, 2013 | 08:49 PM
Alright, sounds simple enough. I was just worried with possibly having to pull the motor just for a block heater! also, I'm running 20w50 oil, could I run something lighter to make for easier starting? Possibly a rotella synthetic? What's the lightest y'all recommend? Thanks for the input by the way!
Old Dec 12, 2013 | 09:39 PM
joebob3093's Avatar
Moderator
15w-40 is what your supposed to run. No wonder its having troubles starting. You can also run a 5W-40 full synthetic in winter to make it start a lot easier
Old Dec 12, 2013 | 09:45 PM
Lol whoops well that explains some of the problem! I will go pick up some of that oil tomorrow and change it out! Thanks! Just ordered the block heater as well. Should make a world of difference! Thanks for the help buddy, much appreciated
Old Dec 17, 2013 | 11:35 AM
mojoman's Avatar
just a heads up...best to drain the antifreeze before attemting this fix...after the drain....gently ease the frost plug out and have a bucket to catch the coolant in the block...just get it leaking a little bit...let it drain...conversely you kin just pop the frost plug out and get a green shower and have to cleanup/buy coolant...hth
mojo
ramrunner01
Feb 25, 2015 11:14 PM
94_12v
Jan 4, 2015 10:37 PM
bikernut
Audio Equipment/Electrical
Dec 18, 2014 03:30 AM
TheBeattie
Dec 4, 2014 07:53 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
