Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
lbz blowing smoke
Old Dec 6, 2013 | 08:46 PM
troyrif's Avatar
Default lbz blowing smoke
I have a stock 2006 durmax lbz 100,000 miles. Yesterday it started to blow thick black smoke ,with no power for about 5 minutes then cleaned up. Took it to local shop to get codes pulled, mass air flow came up. Drove it to work today same problem happened. Read online the egr sticks on these models? should I change the MAF or mess with the EGR. Anyone else had a problem like this? Any help would be greatly appreciated.
Old Dec 7, 2013 | 05:07 PM
j johnson's Avatar
start cheap and clean the mass air flow first..that should clear up any maf codes..if not then you could need a replacement..as far as the egr...has the trk had the update done on the egr..if not then you should be able to get that done under gm..campaign not shure of the number ...do a vin check it will tell you what was done to the trk...hope this helps...scott...
Old Dec 7, 2013 | 06:38 PM
troyrif's Avatar
Default thanks
I bought a new MAF sensor today and it has not done it again. Thanks so much for your help!! I need to clean the EGR next, I heard they get pretty plug up. do I need any gaskets or anything or is it all o-rings? Thanks again
Old Dec 29, 2014 | 06:32 PM
bigrig73's Avatar
Go get a Sinister delete for that bad boy, and never have another issue with the EGR. I had mine blocked from the time it was new, and recently took it right off. Intake was clean as a whistle. Never an issue with it.
Old Apr 1, 2015 | 08:29 PM
j johnson's Avatar
no o-rings that i know of but metal gaskets..because your dealing with high temps....scott
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
mihilo
Sep 16, 2015 10:42 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
gagemotors
Jun 9, 2015 04:24 AM
