Off Road Diesel
Old Apr 14, 2008 | 08:12 PM
raptr85's Avatar
Default Off Road Diesel
im curious. i recently ran out of diesel in the middle of nowhere. all i had was about two gallons of off road red dye diesel. how bad have i messed up my 6.7L engine. i got to a station ASAP and filled up and also dumped a bunch of power service diesel kleen in it. i just dont want to void my warranty.
Old Apr 14, 2008 | 08:34 PM
dodge*this's Avatar
I am not positive but I think the diffference is off road has dye in it. Off road can be either low sulfur or regular from what I read.
Old Apr 14, 2008 | 08:48 PM
Whit's Avatar
Site Mascot
I dont think ya hurt nuttin
off road diesel is the same only it has red dye in it
you have however tainted yer fuel system red and it will always be there
Old Apr 14, 2008 | 08:50 PM
Diesel-N-Dust's Avatar
Not another off road diesel thread!
There is no difference. Red dye is added for tax purposes.That is all.
Old Apr 14, 2008 | 10:00 PM
06 DIESEL's Avatar
It all depends on what off road diesel you put in it. Here we still have a choice between USLD and LSD, at work we have LSD. I would not be worried about it, just keep in mind that one cup of red fuel will taint 500+ gallons of road fuel.
Old Apr 14, 2008 | 10:24 PM
wildbill's Avatar
Most dyed fuel is still LSD. 6.7L's are designed for ULSD. If you ran it all the time, system wouldn't be able to handle it, causing damage. But the little bit you put in, you'll be fine.
Old May 5, 2008 | 11:10 PM
Mr.Krabs's Avatar
Didn't dye my system red
Old May 6, 2008 | 07:09 AM
wildbill's Avatar
Nope. As a matter of fact I ran 3 tanks of it, then went back to clear. I changed my fuel filter shortly after, and didn't see a trace of red.
Old May 6, 2008 | 10:08 AM
johntf's Avatar
I do not know for sure , but aren't they using an ultra violet lite , also dip the tank & or check tail pipe .
Then need to know more about the red dye filter system .
Old May 8, 2008 | 02:27 PM
06Dodge's Avatar
I've been told red fuel will leave traces and show up in your pump even after many hundreds of gallons of fuel have gone through it.
