Airdog
Old Oct 22, 2013 | 09:54 PM
dieselbeginer1's Avatar
Default Airdog
Can I use a airdog 100 made for in tank pump on one with a block pump? I can get a great deal on it so I hope so.
Old Oct 28, 2013 | 09:30 PM
I bought it should be here Wednesday 475 new so if it dont work i will sell it.
Old Oct 29, 2013 | 06:02 AM
97cummins's Avatar
I don't know, I've never heard of the in tank being put on the motor?
Old Oct 29, 2013 | 07:46 AM
lukesdiesel's Avatar
The one for intake pump just includes the draw straw for the fuel tank. You will want to remove the block pump when u install the aridog.
Luke
Old Oct 29, 2013 | 12:25 PM
jigabop's Avatar
he means he bought the pump that comes with the draw straw 5 designed to retrofit into the in-tank pump fuel canister which is an open canister unlike the canister in the tanks for the block mounted pumps that has a draw straw inside the canister...
the pumps are identical, just the one for in-tank comes with a DS-5 where the other does not.
you may or may not need an adapter fitting to attach to the stock QC fitting on the factory fuel canister.
Old Nov 4, 2013 | 07:11 PM
Got it put on just bypassed the stock canister thats what it said to do. The only thing differnt is one quick connect fitting. I just used the it for the stock pick up and push the hose over the return line tube that goes in the filler neck and put a hose clamp on it. Works great 19psi at idle 17psi wot. Now for bigger injectors.
Old Nov 5, 2013 | 11:34 AM
jigabop's Avatar
eew I got rid of that stupid filler neck return long ago and used the factory draw line as an airdog return line, and DS-V as the new draw line...so 2 returns 1 feed.
eliminates 1/4 tank issues 100%
Old Nov 6, 2013 | 09:16 AM
That looKs good. Might have to do that after i get the bed off.
acj
9
Dec 26, 2015 09:54 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
dirtymaxrens
Price Quote - Request A Price
Jan 24, 2015 08:02 PM
justinsbeck
Nov 21, 2014 11:53 AM
