mystery part
Old Oct 22, 2013 | 01:41 PM
outlaw6point9's Avatar
Default mystery part
My frirnd (a fellow 6.9 owner was telling me about a vacuum actuated part that goes on the side of my injection pump that can change the shift points on my c6 does anyone know what he is talking about so I can find out more about it before buying it for the build
Old Oct 22, 2013 | 02:08 PM
Dortiz's Avatar
On the c6 the pump is on the rear lower portion of the transmission,mine was on the driver side, and a vacuum line coming out,also has a sliding pin going threw it , which when bent will cause a lagging shift or no shift at all (ask me how I know, dropped 2 feet off a drop and hit a boulder ) on the c6 it's called a vacuum modulator, should be one nut and a plate holding it in place, if you remove it you should expect to lose a little tranny fluid
Old Oct 22, 2013 | 02:29 PM
4x4manonbroke's Avatar
if its for a c6 , it should be linkage operated ..... like a kick down cable, the vacuum operated cylinder should be for cruise control....... maybe I could be wrong....... never seen a c6 with vacuum operated kick down ....
Old Oct 22, 2013 | 02:45 PM
Thanks 4x4manonbroke I just don't know how to make my 93 cruise work yet tho he said he could change when the trans shifts that's why I am confused, what you said would make more sense
Old Oct 23, 2013 | 04:58 PM
Dortiz's Avatar
In my c6 I never figured out the cc, but I just tested pulling off the vacuum line and driving it and only had first gear, unless I manually shifted into second, so I'm assuming that that's it, they also sell different ones with a high vacuum pressure needed to open soooo
Bslamb
Jeep Liberty
Aug 10, 2015 04:28 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
Mar 4, 2015 08:20 AM
jrsavoie
Feb 6, 2015 09:44 PM
